Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
Instrument Cluster Flashes / Dims
Old Oct 14, 2015 | 09:55 PM
J7979C's Avatar
J7979C
Default Turn Signal Switch Dims Dash Lights
2012 Dodge Avenger 39,400 miles.
I am having an issue with my instrument cluster / dash lights, they dim out every time I use my right turn signal. Left does not do that, and eveything else works great.
I am assuming a short, and needs to be replaced
Would you agree, or do you have other suggestions?
Thanks for your input, appreciate it.
Jim
Old Oct 15, 2015 | 08:33 PM
Sounds plausible. Pull the cluster and check.
Old Oct 16, 2015 | 08:10 AM
J7979C's Avatar
J7979C
I was going to replace the turn signal switch itself. That is where I am assuming the short is not in the cluster.
