Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
2012 Avenger starting issues
Old Sep 13, 2016 | 01:11 AM
sirbrutus's Avatar
sirbrutus
Default 2012 Avenger starting issues
I was trouble shooting the car and put brand new spark plugs checked the battery / alternator / starter and have a new key still hard to start in the am but after that it will start right up when left for a couple hours then hard to start again where is the ignition coil mod or fuel mod wondered if they are faulty any suggestions I found that 2010 Avengers have a key recall but not the 2012 yet I got a new key anyway and still have the starting issue I tested the car on my OEM Tester and all is checked marked green good to go ? HELP
Old Sep 13, 2016 | 09:24 AM
Define "hard to start". Trouble turning over? Turning over and not firing?
Old Sep 14, 2016 | 12:29 AM
sirbrutus's Avatar
sirbrutus
I trouble shooted today by turning the key to the "on" position and waited for the antitheft light as well as all other lights to go off except for the engine light airbag which stayed on because I had not actually started it yet and when I went to the "start" position it started a lot better with only making 2 reps before starting just started having an issue before today starting it by just sticking the key in and starting it up without waiting for the lights such as antitheft etc this where the turning over took about 8 reps before it started up so I guess going to the "on" waiting for the lights on the dash to go out is the way I should of been starting my car all along not sure if long term use the old way caused Mod to key issue or other issues ???
