Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
code 0765 trans problem
Old Feb 6, 2018 | 08:38 PM
roger calvert's Avatar
roger calvert
Default code 0765 trans problem
Trans won't shift from 2nd gear
, have replaced the shift solenoid, cleared codes and it seemed like it was trying to shift, then the lamp came on and we were back in limp mode?
Last edited by roger calvert; Feb 6, 2018 at 08:43 PM. Reason: more information needed.
Old Feb 7, 2018 | 07:44 AM
It is common to overlook clearing the P0765 code and retesting. If the most common repairs do not stop the code from being stored again, it can be a sign of an intermittent issue that requires an in-depth inspection and more complex repairs. Take it to a transmission shop for a proper diagnosis.
Old Mar 12, 2018 | 09:23 PM
William Borris's Avatar
William Borris
Default Did u get your avenger fixed?
Same issue I think it' maybe the wiring or connectors from that solenoid. Any input please?
Old Mar 12, 2018 | 10:20 PM
Inspect the wiring and connectors.
