Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
2008 AVENGER P0339 Trouble HELPPPPP!!!!
Old Aug 24, 2020 | 04:12 PM
2008Avenger's Avatar
2008Avenger
Exclamation 2008 AVENGER P0339 Trouble HELPPPPP!!!!
Engine light on. Code P0339 showing. Replaced the crankshaft positioning sensor twice (thinking bad part out of box) and still showing code. Took to Dodge dealer and was told PCM was bad. $1500. Went online and found replacement PCM and still have the same problem. Engine cranks forever before starting and when started no acceleration. Sometimes nothing when accelerator pedal is pushed. Other times lucky to get to 55mph. Rough intermittent idle. Any and all help is needed. Thanks!!!!!
