Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
2013 doge avenger- rear tires wear out flat at 7k miles
Old Feb 14, 2023 | 09:38 AM
PUNKN8R's Avatar
PUNKN8R
Default 2013 doge avenger- rear tires wear out flat at 7k miles
I am now on my fourth set of tires on the rear of my 13 avenger.
Struts replaced - new wheel bearings installed.
A recent four wheel alignment done.
Mechanic has looked over vehicle says everything seems to be good and I am completely stumped and wasting funds.
Does anyone have an idea on what I might check?
Has anyone else stumbled across this situation????
PLEASE HELP ???
-PUNKN8R-
Old Feb 14, 2023 | 10:32 AM
dodgetruck2's Avatar
dodgetruck2
Do you have a picture of the tires, how are they worn? What tires are you buying?
Old Feb 14, 2023 | 11:04 AM
PUNKN8R's Avatar
PUNKN8R
Default 13 avenger tire issue
I do not have any pictures, but all sets of tires mentioned have been worn out flat across the entire tire with no signs of uneven wear at all.
I have even gone with the changing of brands and costs of tires.
Discount tires have warrantied the tires however they are saying there is an issue with my car's suspension, and this will be the last warrantied set they will provide to me.
The car is currently back in the Auto shop being gone over again.
My mechanic says they will confirm alignment and check over rear components again.
Any ideas?? Would be helpful...
Old Feb 14, 2023 | 11:17 AM
PUNKN8R's Avatar
PUNKN8R
Default 13 Avenger tire isssue.
That last set that wore out on rear again after 4 tire replacement at approx. 7,000 miles and were Continental touring tires at 199.99 a piece.
All 4 sets (rear only)are wore out at approx. 6-7'000 miles according to receipts on file.
Old Feb 14, 2023 | 06:50 PM
dodgetruck2
flat wear would indicate a decent alignment also, shouldn't they be rotated sooner? not that i makes a big difference but should be able to double the mileage I would think.
I would think you could've caught this by now but is the brake dragging? I mean your brakes should be purple or on fire by now i would think if they were dragging but who knows
Old Feb 14, 2023 | 09:28 PM
PUNKN8R's Avatar
PUNKN8R
I have had tires rotated at 3400 miles on the last set and fall were not worn at 2/32nds of an inch but another 3500 and the ones put on rear were bald again.
Checked back with mechanic rear brkes not dragging and brakes were all replaced just at about 2700 miles ago ....
