Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
2008 Dodge Avenger SXT 2.7L
Old Sep 17, 2023 | 09:42 AM
Blasiann14's Avatar
Blasiann14
Default 2008 Dodge Avenger SXT 2.7L
I’m having a problem with my passenger window, it’s goes down but will not go back up , I started with replacing the passenger window switch & drivers window switch that didn’t work so I replaced the passenger window motor & that didn’t work either so then I replaced the ENTIRE PASSENGER DOOR So new window n all still didn’t work, on the drivers side I can work every window and even put the passenger window down but not up and same with the passenger switch I don’t know what else it could be.
If you happen to say it’s the wiring, where/ what wiring am I checking? 😩
It to the point where my window is stuck completely down.
