Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
Need Help
Old Jul 17, 2024 | 04:20 PM
cjones1552's Avatar
cjones1552
Default Need Help
I have changed my alternator which went out and have had problems with my car starting since. Radiator hose and belt went at same time and replaced same day. I got an alternator and put on was able to jump car and start drove that day and when got home seemed fine. Next day could not start even with a jump. Terminals on battery were corroded and I was informed my battery may have been zapped from alternator. I cleaned terminals and replaced battery. When I go to start car, it still will not start and just clicks. I replaced all fuses including relay fuses. The car is still having the same problem and will not start even with a jump. The battery does not keep charge and when jumped it will start for a few minutes then shuts off.
Old Nov 8, 2024 | 04:52 PM
Belle Star's Avatar
Belle Star
Default Puzzle
Apparently no one keeps the schematics for the 2013 Avenger and they never put it back together correctly herein lies all the problems Just thought you should know
Old Jun 21, 2025 | 12:40 PM
Johnboy173's Avatar
Johnboy173
Default No crank
I just assisted another person,same clicking,download codes ,have key checked by capable/experienced tech, NEW KEY AND key PROGRAMMING FIXED NO START. Good luck,,,
