cvt-2 trans dip stick
I know that you should check the trans fluid every 15000 miles on the cvt -2 trans
were can i get that dip stick ? Found the tub were the dip stick goes says dealer only
would like to do that myself with my own dip stick.
Any answers on that -----------------------------------------------Thanks
Clean off the oil dipstick, now put it done the cvt-2 trans tube, take the cover were th batt.
is at( no tools needed) you will then see the batt . to the left of that you will see the tube
take top off stick the oil dipstick down it and it should read safe just like you would read
your oil stick. The fluid is very clear and hard to see .
