Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
No shift feeling
Old Oct 29, 2007 | 02:22 PM
06ChargerSXT's Avatar
06ChargerSXT
Default No shift feeling
Just last night a co-workerhasone for a rental I asked to
drive it to see what it was about.I get in put it in drive felt it shift
then when i got on it rpm's climb to shift point and thats when It stood at 6000 but kept
gaining speed is it supposed to do this felt likedriving a Saturn
with there pulley system transmission.
Old Oct 29, 2007 | 05:05 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: No shift feeling
its normal its a ctv tranny
Old Oct 29, 2007 | 05:06 PM
dragon8master's Avatar
dragon8master
1. Please learn to use periods to separate your sentences. It took me ten minutes to figure out what you were saying.
2. It's called a CVT, or contiuously variable transmission ( or transaxle ).
3. Yes, it is supposed to do that. I just wish they would have set that hold point at about 5800 rpm where the actual peak power is. Those extra 200 rpm just make slightly less power and use more gas. But, maybe that's just my opinion, I don't know.
Old Oct 30, 2007 | 04:35 AM
06ChargerSXT
Thanks for the info.
Old Oct 30, 2007 | 10:45 AM
StepOnIt's Avatar
StepOnIt
As noted in the owner's manual there is a "detent point" where the engine will either stay at a lower rpm (in from experience it is about 3500 rpm) during acceleration, or go all the way to 6000 in order to use the maximum power depending how far you push the pedal. BTW the maximum HP is at 6,400 rpm (not 5,800) with the 2.0L engine.
I find that in city driving there might be another range where the engine goes to about 2200 during "soft" acceleration, like when moving slowly in the traffic.
Most people are used to automatic transmissions with gears, going to a CVT may require some adaptation in the way we drive and use the engine's capabilities.
Old Nov 2, 2007 | 05:03 PM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
It takes some getting used to. I use the slapstick a lot myself.
