Sunroof stuck!!
I searched to see if this has been cover before. Sorry if it has. My wife opened her sunroof and now it is stuck open
. I have checked all the fuses and the switch. No power to the switch. Does any one have a idea were to look for loss of power? And do you know is there a manual way to close with out removing the headliner for now??????? Any help will be awesome!!
thanks!!
Matt.
. I have checked all the fuses and the switch. No power to the switch. Does any one have a idea were to look for loss of power? And do you know is there a manual way to close with out removing the headliner for now??????? Any help will be awesome!! thanks!!
Matt.
Does your rear window wiper still work?
The reason I ask is because if the sunroof has an electrical glitch
posts have indicated the rear wiper will also have a problem.
The fuse for the sunroof/cigar lighter is #16 - 15 amp light blue and there is also
#24 - 25amp natural color associated with the sunroof.
There also several posts regarding the track binding with people
pulling down gently on either side to get it moving again.
The last thing is a CANbus glitch which means the dealer has to
reflash the TIPM module with the StarScan tool.
Forgot to add sometimes disconnecting the negative battery cable
for 10-20 minutes resets computer glitches in the Caliber.
Sorry those solutions didn't help,I have not read a post in 3 yrs
that would indicate a manual method of closing the sunroof.
I would hazard a guess that the dealer is your only choice-
I hope you have a good one,good luck.
So guess I need to take it to the shop. Is there a way to manually close it? It is raining off and on here?
