Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
07 Caliber shaking at stop light.
Old Jan 6, 2012 | 05:17 PM
degree01's Avatar
degree01
Default 07 Caliber shaking at stop light.
Hello, i was wondering if someone could please help me with an issue I’m having with my 07 Caliber, when I’m driving it works fine but as soon as I stop at a red light, it starts to shake, kind of like if it is not idle enough but it is cause the RPM's are at about 800 and when i stop i have to put the car on neutral so that it stays normal then when the light turns green i put back in drive and once i take off it works fine or if I’m in park it works fine, it's only when it is stopped and on Drive, it was working fine and just started to do this, no engine light. Thank you in advance for your help.
Old Jan 7, 2012 | 12:01 AM
steak59's Avatar
steak59
Try update the software on the computer first, there is a TSB for this concern, you might have to hit the dealership and talk to them.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN, 18-017-08 DATED
APRIL 23, 2008, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL
REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION
OF 2007 MODEL YEAR.
THE StarSCAN® FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM
THE INTERNET.
StarSCAN® SOFTWARE LEVEL MUST BE AT RELEASE 9.02 OR HIGHER.
StarMOBILE DESKTOP CLIENT -OR- StarMOBILE STANDALONE MODE MAY ALSO
BE USED TO PERFORM THE FLASH.
SUBJECT:
Flash: Idle Vibration From a Stop With Closed Throttle
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM).
NOTE: Vehicles equipped with a CVT transmission must have the transmission
control module (TCM) checked for the latest software level whenever the
PCM software is updated. If newer TCM software is available, it must be
installed. Failure to maintain software coordination may result in MIL
illumination or driveability concerns.
MODELS:
**2007** - 2008 (MK49) Compass
**2007** - 2008 (MK74) Patriot
**2007** - 2008 (PM) Caliber
NOTE: This Bulletin applies to **2007 and** 2008 models equipped with a 2.0L or
2.4L engine & automatic CVT transmission (Sales Code ECN or ED3 with DAV
or DAW) built prior to April 2, 2008 (MDH 0402XX).
NUMBER:
18-017-08 REV. A
GROUP:
Vehicle Performance
DATE:
September 11, 2008
SYMPTOM/CONDITION:
Some customers may experience an idle vibration. The condition may occur under the
following parameters:
Vehicle in Drive.
No throttle input (foot “Off” accelerator pedal).
Foot “Off” Brake.
Vehicle speed between 0 and 5 miles per hour.
DIAGNOSIS:
Using a Scan Tool (StarSCAN®) with the appropriate Diagnostic Procedures available in
TechCONNECT, verify all engine systems are functioning as designed. If DTC's are
present record them on the repair order and repair as necessary before proceeding further
with this bulletin.
Of course, hows the maintainence record? Air Filter, PCV valve? Tune Up?
ask your dealership if they would update the Computers in the car for free if you purchase something like a Tune Up. At least we do. unless they can find something else wrong with your car, I would recommend you starting with a PCM update and some maintainence catch up if you havent done it yet.
Old Jan 7, 2012 | 08:49 PM
degree01's Avatar
degree01
Thank you I will do that and i really appreciate that.
Old Oct 9, 2017 | 03:36 AM
Manuel Tamayo Gonzalez's Avatar
Default This helps
Thanks a lot .im having exactly the same problem with mine .
Old Dec 12, 2017 | 12:15 PM
Richard Geiger's Avatar
Richard Geiger
I got engine vibration at stop as well, but I see noticeable movement of the engine at idle, your issue could be the top motor mount.
Old Mar 5, 2018 | 07:32 PM
Poetic Art's Avatar
Poetic Art
Can anybody help with a car problem I am having? My Dodge Caliber will not crank over and I have change the starter, check the battery, reset the computer, and tried to jump start it. I am at a point to where I have no Ideal of what could be wrong. If you have some good tips I will be welling to try them out. Thanks Again.
Old Oct 26, 2021 | 03:52 PM
FL dodge's Avatar
FL dodge
Default Same issue here no codes, runs great
Agree same here here I’m glad you provided the Bulletin mechanic could not figured out or just lazy to research.
