Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
CVT fluid change.
Old Feb 16, 2012 | 11:28 PM
alwaysdutch's Avatar
alwaysdutch
Default CVT fluid change.
I know that there are probably several threads about the CVT transmission, but I was hoping if anyone had done a CVT fluid change, or maybe a DIY.
Unless it is really needed to get this done by the dealer or special mechanic, I like to know if it is possible to do it, what fluid is best, and if special tools are needed.
I also own a VW JEtta, which has also called "lifetime" fluid, but with some special tools i was able to do this as several others had done that.
Any help is appreciated.
Old Feb 16, 2012 | 11:49 PM
steak59's Avatar
steak59
well... you need a $50 Dipstick, that's about it.
Fluid Wise, ONLY use mopar OEM fluid. even tho I don't think you have a cheaper option anyway.
procedure is like normal trans, need Fluid, Filter, and Gasket.
