2009 Dodge Caliber 2.0L
I keep getting two codes everytime i scan my Caliber: P2017 & P2004. I dont know how to fix it Or find out what it really is i checked on websites amd here on this forums but not much info and these two codes are the same thing...?. Everytime i turn on my car it gives me this type of rattling noise in the engine also sounding as if its got a muffler but doesn't. This all happened when i was driving my mph started going down, even with me pressing the gas. Then this red light comes up |lightning strike between these two lines|....crashed without warning. I checked if recalls, found some but dont know if its for my car cause i called dealer ship and they said no. How would i fix this?
Hi my name is Natalie.
Originally Posted by Natalie392
(Post 2875363)
Here are the descriptions of the two error codes you are getting. It seems to indicate to start to diagnose by checking the intake manifold valve. P2004-INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN
Possible Causes (K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE (K602) MFV SIGNAL CIRCUIT SHORTED TO VOLTAGE (K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND (K602) MFV SIGNAL CIRCUIT SHORTED TO GROUND (K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO (K900) SENSOR GROUND CIRCUIT (K602) MFV SIGNAL CIRCUIT SHORTED TO (K900) SENSOR GROUND CIRCUIT (K602) MFV SIGNAL CIRCUIT SHORTED TO THE (K857) 5-VOLT SUPPLY CIRCUIT (K857) 5-VOLT SUPPLY CIRCUIT OPEN OR HIGH RESISTANCE (K602) MFV SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE (K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE (Z909) GROUND CIRCUIT OPEN OR HIGH RESISTANCE MANIFOLD FLOW VALVE INTAKE MANIFOLD POWERTRAIN CONTROL MODULE (PCM) P2017-INTAKE MANIFOLD RUNNER POSITION SENSOR CIRCUIT HIGH
Possible Causes (K857) 5 VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE (K602) MFV SIGNAL CIRCUIT SHORTED TO VOLTAGE (K602) MFV SIGNAL CIRCUIT SHORTED TO THE (K857) 5 VOLT SUPPLY CIRCUIT (K602) MFV SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE (K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE MANIFOLD FLOW VALVE POWERTRAIN CONTROL MODULE (PCM) |
Welcome to DF
The code P2004 is the short running valve and should be looked at. I will move you post to the Caliber section. And if you really need to know if you have recalls. Send me a pm with last 9 of the vin and mileage. |
Welcome. I have heard that the intake manifold usually needs replaced when this happens. You may also be able to replace the valve as mentioned above.
