Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
dodge caliber ABS on engine off
Old Feb 3, 2017 | 09:30 PM
jansnaile's Avatar
jansnaile
Default dodge caliber ABS on engine off
Hey,
I have a 2008 dodge caliber. The problem is with the ABS light on and then the engine suddenly was off. I changed the brake pad last week, the radiator and the fan. Please any advice? thank you.
Old Feb 3, 2017 | 10:11 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
On the surface, it sounds like you have some sort of BUS communication issue. You probably should have it looked at by a competent repair shop.
Why did you change all hat? Did it run fine before? What engine? How many miles? Need more information.
Old Feb 3, 2017 | 10:39 PM
jansnaile's Avatar
jansnaile
The car has 124000 miles, engine 2.0L I changed the brake pads at pep boys because it was bad, then after two days, the radiator starts leaking the coolant and it was replaced with a new one at another dealer.
Old Feb 3, 2017 | 10:41 PM
TNtech's Avatar
TNtech
Don't let Pep Boys check your electrical issues. For your own good.
