Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Caliber European version
Old Feb 1, 2018 | 12:20 PM
DodgeEU's Avatar
DodgeEU
Default Caliber European version
Hello,
I kindly ask your advice on the following matter:
Dodge Caliber, 2.0 Diesel, 6MT, 140HP, European model with VW Passat B6 engine and gear box.
90.000 miles, have it since new.
When using the lights, the instruments panel should also be lightened (fuel and heat gauges, speedometer, torque).
What it does instead is to blink for minutes, or not blink at all; but it does not light until, at some point it starts suddenly.
If I gently kick the upper part of the instruments panel, there is an influence on the blinking pattern.
Same when the road is not smooth.
Any thoughts?
Thank you!
BTW, Dodge spare parts in Europe are far more expensive than Mercedes spare parts.
Old Feb 5, 2018 | 06:17 AM
DodgeEU's Avatar
DodgeEU
Default Solution found
found it on youtube searching Dodge Caliber Instrument Cluster dashboard light blink
seems to be a manufacturing problem
