rear washer indicator lights not working
Old Apr 14, 2007 | 03:18 AM
dhoelod's Avatar
dhoelod
Default rear washer indicator lights not working
I tried to fix a the indicator light on the front console. I pulled the switch off to find an LED light. I thought I should pull it to replace, but discovered it was attached as part of the circuit board [:@]! Do I need to replace the whole switch assembly? I would appreciate step by step to avoid futher problems if possible!
Thanks
