'98 Flashing AC Panel lights
Old Mar 14, 2013 | 04:15 PM
td1's Avatar
td1
Originally Posted by Cougar41
wow! what a goldmine!! THANK YOU!!!!
td1
Old Sep 8, 2015 | 07:59 PM
DianeLep's Avatar
DianeLep
Originally Posted by amandalibby1
Hello,
Goodness, goodness has this been a lot of trouble for just some blinking lights for changing a battery. Well I have the hookup on what to do, so do not fret anymore. I got it from another site and it only too 6 min. to complete:
"All you need to do is start your van. Slide your temp lever all the to the right (full cold)-mine was to the left. Turn Mode Control to 'panel' (the one that sends air to your face only). Turn the 'blower switch' to all the way to full. Now go to the left most three buttons. Simultaneously press and hold two buttons, the top one (rear wiper) and the bottom one (rear washer fluid). Hold these two for a few seconds. Once the lights come on solid and begin to flash, you can let go. A microprocessor will now take a few minutes to orchestrate the calibration of the air conditioning system. You will feel the air blow out of all the different zones at different intervals and see lights come on and go off. This means the AC computer has completed it's re-calibration cycle. Pressing the last (slow) flashing button complete the process. Turn off the ignition and restart the van. A successful calibration is indicated by the absence of blinking lights" OK this does work, but you need to watch the lights, because it start all over again if you miss the slow blinking light (top-left). Good Luck, Amanda
[/align]
THANK YOU for taking time to step through this. This sounded too crazy to be real, but of course as you know(!) it worked!
Still trying to track down other whacky electrical stuff, and I think the flashing dash was a side effect of other efforts. Started with erratic power window and lock malfunctions. Now they seem to be working but I've got battery drain that I can't pin down. Amp meter in series shows around 42mA draw. New battery...replaced it somewhere along the line trying to correct the window/lock issue.
Thanks again -- Diane
