AC blowing cool one side warm driver side
Old Jul 27, 2007 | 10:50 PM
matyree's Avatar
matyree
Default AC blowing cool one side warm driver side
My 2001 Dodge Grand Caravan Sport is blowing cold air on the passenger side, but the driver side is warm air. I've filled the freon (r134), I've changed the cabin filter, and I've checked to make sure that the dual zone mechanism is moving. All those things are covered. Any thoughts?
Old Jul 28, 2007 | 02:25 AM
RickMN's Avatar
RickMN
Default RE: AC blowing cool one side warm driver side
Check the driver's side actuator blend air motor to see if it opens and closes the blend door. If it doesn't move, disconnect it from the door shaft and try to move the door manually. If the door moves and you get cold air, you probably have a bad actuator.
Old Jul 28, 2007 | 09:01 AM
Dodge Tech's Avatar
Dodge Tech
u have a leaking condensor at the lower right end look for a wet spot at the corner.
Old Jul 28, 2007 | 11:49 AM
matyree's Avatar
matyree
am I looking for the leak on the right corner of the condenser?
where is the actuator?
Is the condenser located near the cabin filter?
Old Jul 28, 2007 | 01:06 PM
Dodge Tech's Avatar
Dodge Tech
hehe no the condensor would be ouside infront of the radiator. stand infront of the van and look at the lower left hand side. it will be wet on the side.
