Please Help
Old Aug 8, 2007 | 12:33 PM
drp3407's Avatar
drp3407
Default Please Help
Could someone tell me the easy way to remove the drivers side door panel on my 2001 Dodge Caravan without breaking something? I can't get it to come loose.
Old Aug 8, 2007 | 01:31 PM
chopper's Avatar
chopper
Default RE: Please Help
I don't know for sure but it should be held on by a few screws and several clips.The clips can be removed with a flat screwdriver but a tool just for this purpose is best.It looks like a flattened two pronged fork and costs about $6 at an autoparts store.
Old Aug 12, 2007 | 10:33 PM
dishdude2k's Avatar
dishdude2k
ok..i just took mine off.. and it pissed me off something fierce.. but here goes... on the handle (the one you open the door with).. theres one screw.. then one on the SIDE.. on the edge of the door.. then you have to carefully pry that off with a screw driver.. take off only the TOP layer of it.. and you have to finaggle the switches outta there.. then theres another screw under that.. take that screw out.. and the screw out of the door handle (the one you CLOSE the door with) itself.. next take a screw driver and start at the bottom left of the door.. and pry it off.. its got a bunch of clips.. you will have to remove the clips from the door and put them back onto the panel when you rdone before you can put the panel back on the door.. let me guess.. window regulator? i am getting ready to replace both of mine. i have to beat the hell outta my door for now to get them to work when they quit.
