Evans coolant and 7 lb radiator cap
Old Sep 3, 2007 | 04:10 PM
caravan4's Avatar
caravan4
Default Evans coolant and 7 lb radiator cap
Conversion to an all evans colant system is now complete in my 3.3 l 2005 GC.
Both heater cores and radiator should last a long time.
[IMG]local://upfiles/71013/8C0F8550ADC0460B984AC178C4C96477.jpg[/IMG]
Old Sep 4, 2007 | 09:26 PM
Mag's Avatar
Mag
Default RE: Evans coolant and 7 lb radiator cap
Hey - looks great, but could you expand on what the Evan's coolant sys is? That's a new one on me lol
Old Sep 6, 2007 | 02:20 PM
caravan4's Avatar
caravan4
http://www.evanscooling.com/main25.htm
Around $37/gallon delivered.
Big cost in replacing heater cores in these vans so Evans provides me with option of reducing the pressure being put on the heater core/radiator by 56%. Chep heater cores and radiators just will not stand up to 16 psi for very long. The following benefits also are nice.
THE BENEFITS OF EVANS NPG+ COOLANT FOR PASSENGER CAR ENGINES INCREASES POWER PROTECTS FROM BOIL-OVER IMPROVES FUEL ECONOMY DOES NOT DEVELOP HIGH PRESSURE ELIMINATES SYSTEM SCALING ELIMINATES CORROSION REDUCES DETONATION ELIMINATES PUMP CAVITATION REDUCES EMISSIONS LENGTHENS LIFE OF ENGINE EXTENDS RADIATOR LIFE LIFE OF ENGINE COOLANT - 500,000 MILES LENGTHENS LIFE OF COOLANT PUMP PROLONGS HOSE LIFE LOWERS MAINTENANCE COST LESS ENGINE NOISE REDUCED TOXICITY
ADDITIONAL NPG+ COOLANT BENEFITS TO AUTOMOTIVE MANUFACTURERS
REDUCES WARRANTY COSTS OFFERS THERMAL MANAGEMENT FLEXIBILITY MAKES POSSIBLE SMALLER, LIGHTER ENGINES PERMITS USE MAGNESIUM ENGINES OFFERS POSSIBILITY OF SMALLER RADIATOR OPENINGS ALLOWS ALTERNATE LOCATIONS FOR RADIATOR ENABLES CHOICES FOR FRONT-END PACKAGING
