Desperately seeking owner of 87 caravan w/2.6L
Old Oct 6, 2007 | 10:26 PM
deadcaravan's Avatar
deadcaravan
Default Desperately seeking owner of 87 caravan w/2.6L
Please help me if you own an 87 caravan. It must be an 87 non-california, non-high altitude van. Other years are different. I just put an engine in mine and apparently marked everything with washable marker. I managed to find where everything went except a few vacuum lines. This is all that is stopping me from getting it running. If any someone could take a few pics for me or describe where they go I would really appreciate it. I need to know where the two go that come off the bottom of tube thatruns between the air box and top of carb. I also need to know where one on top of the same thing goes(not the one that runs down it to the airbox, but the other) I also need to know where the two that run over the transmission towards the front of intake go. I believe the one goes directly to the bottom of the carb but with this many loose ends I want to make sure. There is also one in question between the carb and alternator. Too complicated to describe so I'm hoping for some pics. Or if someone can tell me where the others go it might be enough to figure it out along with the unhelpful vacuum diagram on the bottom of the hood.
Old Oct 22, 2007 | 01:10 PM
pr0cess0r's Avatar
pr0cess0r
Default RE: Desperately seeking owner of 87 caravan w/2.6L
here is the vacuum for the 1987 2.6 federal im 100% sure its the one you need its not high altitude ou californian.
its in pdf format http://rapidshare.com/files/64402834...eral_.pdf.html
