ABS Light (Retrieving Fault Code)
I've got a 2002 Dodge Caravan w/ABS warning light on. I know that you can retrieve the "check engine" fault code by turning the key 3 times, but I don't seem to get any info about the fault code for the ABS light. I just get a "done" in the odometer display. I assume that the fault code for ABS is not displayed in the odometer. Nor have I found any info in my service manual or the web about reading ABS fault codes, and diagnosing the problem.
What's the least expensive way to get the ABS fault code read? Should I pay the dealer 1/2 hour labor?
Greg
Greg
