stalling and erratic run
96 3.3 caravan a/c compressor had a bearing go out. took compressor off and replaced with a bypass pulley. bypass pulley was about an inch in diameter larger than the compressor pulley. got a bigger belt. car ran fine for a couple of 4 mile roundtrips. went to start, car wouldn't start. tried a few more times finally started was running ok then sputtered and died. was told to try and reset the comp by disconnecting battery for a few minutes.
now, starts ok and runs ok for a few minutes then runs very erratic and tries to stall but doesn't. as far as i know i didn't pull anything lose changing the pulley. codes 54 , 25 with the trans prob this thing am really getting annoyed help!!!!!!!!!!!!! |
RE: stalling and erratic run
code 54...cam sensor
Code 25-Target idle not reached-actual idle speed does not equal the target idle speed check the iac motor for carbon. take it off, give at good cleaning with carb cleaner and reinstall it. |
