Front And Rear Washer Fuse Location
Old Feb 10, 2008 | 11:50 AM
brodericktj's Avatar
brodericktj
Default Front And Rear Washer Fuse Location
Any one know where the front and rear washer fuse is on a 2006 Grand Caravan. The manual says fuse location #33 in the IPM. I've attached picture of my IPM. The slots are not numbered. There is a fuse location marked FT/RR WSHR. I'm assuming that's it, but lo and behold there's nothing there.The front and rear washers did work when we bought the van. The area in question is the cluster of three yellow fuses in the top center of the first picture. On the close up of the cover you can see below those three fuses the cover reads FT/RR WSHR. If you look below those three fuses in the third picture you'l see the spot is empty.If I try and put a fuse in that spot it just jiggles around and isn't making contact with anything. Any help would be appreciated.
[IMG]local://upfiles/83644/CBBFD14B1ED8450EBD5922BCF1E79F72.jpg[/IMG]
[IMG]local://upfiles/83644/43FC81F9449247ECACB59C8E14DC19B1.jpg[/IMG]
[IMG]local://upfiles/83644/53302050D88C43EFA522CC6962251581.jpg[/IMG]
