95 carvan front end shake
I have 95 Dodge carvan se sport van. in november i had 4 new sears road hanlder tires put on. On a trip back from North Dakota it statrted to shake like out of balance at low and high speed. Sears found a tire separated.the next two time it happened sears said they were out of balance and maybe a bent rim. Just rencently i took it back a again and their master tech said i need a new front motor mount and the right side driveshaft replaced. I did both plus a bearing and Hub. i also switched tires around and even put the minin spare on the right side and still had a shake and vibration at accelration on the right side.</P>
any suggestion will help getting very frustrating.</P>
hunter</P>
</P>
</P>
I know right now, I need a wheel aliegnment because my van starts pulling to the right a bit, and it has a little shake to it, not much, but a little. Hardly noticable!</P>
redriderbob</P>
</P>
Well I got the very bad shake gone. All this time i was thinking in the right front it was my driveside axle i replaced Feb 03 I have 22,000 on the axle.</P>
</P>
HUNTER</P>
</P>
