Timing Belt
Old Mar 9, 2008 | 09:42 AM
dt4ts3's Avatar
dt4ts3
Default Timing Belt
When is the timing belt due on a 2002 4 popper caravan? Our manual is gone.
Old Mar 9, 2008 | 02:05 PM
jdl's Avatar
jdl
Default RE: Timing Belt
The gates database says 120K. Don't quote me on that, you can look for yourself, gates.com, timing belt link. It also says the 2.4 dohc engine vin B is an interference engine. If that is the case, if the belt even looks worn, replace it, I don't care how many milesthe belt has on it.
Old Mar 10, 2008 | 09:13 PM
vlmuke's Avatar
vlmuke
I believe the serive manual say 100K but not 100% sure depending on the motor might want to change the water pump while your at it
Old Mar 12, 2008 | 10:47 PM
blazered's Avatar
blazered
90,000 miles or 144,000 km.
You can down load the 2004 owners manual which is very similar from the Dodge web site:
http://www.dodge.com/en/owners/manuals/index.html
