Build Sheet
Old Apr 19, 2008 | 03:52 PM
shedberg's Avatar
shedberg
Default Build Sheet
Can someone help me out? I need a build sheet for an 03 Dodge Caravan, so I can find out if it has ABS...
The VIN is 1D4GP25R63B135444
Thanks in advance.
Old Apr 22, 2008 | 10:37 AM
tazman444's Avatar
tazman444
Default RE: Build Sheet
Call the dealership with your VIN and they will tell you or give you a printout of what your van has in it. You can also follow the lines from the brake fluid container to the ABS pump mounted on a bracket above the transmission.
