Power locks not working
Old Jun 30, 2010 | 11:38 AM
brettj2408's Avatar
brettj2408
TSB# 08-040-04
Driver And Passenger Power Door Lock Switches Inoperative And Opening the
Liftgate Triggers The Theft Alarm
Old Jul 31, 2010 | 05:42 PM
stev's Avatar
stev
Thanks for the many replies on this thread. My wife's 2005 SXT Grand Caravan locks went non functional last month. It's been a pain manually locking and unlocking. Also, why does the drivers door only have a key lock and not the passenger side.
OK, I'll try the IOD fuse/relay trick and see if that fixes things.
(It worked !!!)
This is the second wacky issue with the electronics. I had once started the van with the key FOB and accidentally pressed a button on the FOB while starting. The dash lights and all of the gauges stopped working. So, driving the van at night was not possible. It took three days to figure out how to hit the right key FOB combination and start the van to reactivate the dash and gauges. errrr. LOL
Old Jul 31, 2010 | 05:50 PM
stev's Avatar
stev
Found this ...
TSB NUMBER: 08-040-04
THE DRBIII® FLASH FILES FOR THIS BULLETIN ARE AVAILABLE ON
DealerCONNECT.
FOR MARKETS OUTSIDE OF THE UNITED STATES AND CANADA, THE FLASH
FILES AND REPROGRAMMING INSTRUCTIONS WILL BE AVAILABLE ON ITIL/ISIS
DVD FEBRUARY, 2005.
SUBJECT:
Flash: Driver And Passenger Power Door Lock Switches Inoperative And Opening the
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Body Control Module
(BCM) with new software.
MODELS:
2004 - 2005 (RG) Chrysler Voyager (International Markets)
2004 - 2005 (RS) Town & Country/Caravan
NOTE: This bulletin applies to 2005 vehicles equipped with Power Locks only (sales
code JPB) and 2004 - 2005 vehicles equipped with Power Locks, Power
Liftgate, and Security Alarm (sales codes JPB, JRC and LSA respectively).
SYMPTOM/CONDITION:
The vehicle operator may describe:
· The alarm sounds erroneously when opening the power liftgate using the key fob
while the Vehicle Theft Alarm (VTA) is armed.
· The driver's and/or passenger's door lock switches are inoperative.
The technician may find "Left Unlock Output Failure" and/or "Right Unlock Output Failure "
Diagnostic Trouble Codes (DTC's) in the BCM.
NUMBER: 08-040-04
GROUP: Electrical
DATE: December 9, 2004
DIAGNOSIS:
1. Using a Scan Tool (DRBIII®) with the appropriate Diagnostic Procedures Manual,
verify all systems are functioning as designed. If DTCs are present, other than those
listed above, record them on the repair order and repair as necessary before
proceeding further with this bulletin.
2. With the ignition switch in the "RUN" position, determine the original part number of the
BCM currently in the vehicle. Using the DRBIII® select:
a. "DRBIII® Standalone"
b. "1998 - 2005 Diagnostics"
c. "All (Except Below)"
d. "Body Interior"
e. "Body Computer"
f. "Module Display"
g. Record the "Software part #" on the repair order for later reference.
h. Check DTC's
3. If the vehicle operator describes or experiences the Symptom/Condition, use the
following table to determine the appropriate action.
Year Model BCM Software P/N Action Required
2004 RG/RS 04836966AG or earlier Perform Repair Procedure
2005 RG 04840935AC or earlier or
04843198AA
2005 RS 04839664AE or earlier or
04841954AA
2004 RG/RS 04844016AA or higher Further diagnosis is necessary.
This bulletin does not apply
2005 RG 04843198AB or higher
2005 RS 04844017AA or higher or
04841954AB or higher or
04843752AA or higher
SPECIAL TOOLS/EQUIPMENT REQUIRED:
NPN Battery Charger
CH2002 General Purpose Interface Bus Cable Assembly
CH6000A Scan Tool (DRBIII®)
CH7000A/7001A J1962 Cable with red DRBIII® connector
TechCONNECT Workstation
NOTE: An updated J1962 cable has been released. This cable has a red colored
connector at the DRBIII® connection. Use this cable whenever a flash is
being performed.
REPAIR PROCEDURE:
NOTE: Whenever a controller is programmed, the software in the DRBIII®; must be
programmed with the latest revision level available.
NOTE: If this flash process is interrupted/aborted, the flash should be restarted and
then follow the directions on the DRBIII®.
1. Before beginning the reprogramming procedure, remove any old flash reprogramming
files from the DRBIII® memory. To clear the memory from the MAIN MENU:
a. Simultaneously press the "MORE" and "YES" keys.
b. A screen will appear requesting a "COLD BOOT".
c. Follow the on screen instructions by selecting the "F4" key.
d. When the DRBIII® reboots to the MAIN MENU, proceed to Step #2
2. Connect the DRBIII® to TechCONNECT. Open TechTOOLS and verify that the
"DRBIII® Status: Connected" message is in the upper right corner of the TechTOOLS
screen.
3. Enter the "Software part #" recorded during "Diagnosis" in the "Parts Criteria" area and
select "Show Updates". TechTOOLS will populate the available updates.
4. Select the calibration.
5. Select the "DRBIII" radio button which is next to the "Download/Update" button.
6. Select the "Download/Update" button.
7. Monitor the "Flash Download/Update Progress" window on the TechCONNECT and
follow the instructions on TechCONNECT. When the flash process is complete,
proceed to Step #8.
8. Disconnect the DRBIII® from TechCONNECT.
9. Open the hood, install a battery charger and verify that the charging rate provides
approximately 13.5 volts.
10. Connect the DRBIII® to the vehicle.
11. Turn the ignition to the "Run" position (engine not running).
12. Download the flash from the DRBIII® to the vehicle. Using the DRBIII® select:
a. "Vehicle Flash"
b. Follow the directions on the DRBIII® screen.
13. Verify that the problem cannot be repeated by cycling the ignition switch OFF/ON and
actuating both door lock switches a few times. If any door lock failure still persists then
further diagnosis is necessary. Verify the BCM "Software p/n" was updated to the new
software p/n using Diagnosis Step #2.
NOTE: Due to the BCM programming procedure, a DTC may be set in other modules
(TCM, PCM, MIC, SKIM, etc.) within the vehicle, if so equipped. Some DTC's
may cause the MIL to illuminate. Check all modules using "Module Scan",
record the DTC's, and erase these DTC's prior to returning the vehicle to the
customer. Erase any DTC's in the PCM only after all other modules have had
their DTC's erased.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
08-19-02-96 Reprogram Body Control Module 0.5 Hrs.
FAILURE CODE:
FM Flash Module
This will cost about 0.5hrs of Dealer Service Labor based on the dealer rates.
Old Nov 8, 2011 | 09:38 PM
vidflix's Avatar
vidflix
Thumbs up Pulling the IOD fuse works!
After reading posts on this forum, I have had no working locks via remote or on the driver's door controls. I also have a 2005 Caravan. I just tried pulling the 20 amp IOD fuse, waited 10 seconds and reinserted the fuse. I heard a very faint "click" when I put the fuse in. I tried my remote first...and presto! the locks work again! I tried using the lock controls on the driver's door, and they work as well!
Thank you so much posters!
Old Dec 12, 2011 | 02:17 AM
ramon4x4 dodge's Avatar
ramon4x4 dodge
New Member
Default 2007 ram 1500 4x4 door locks
I took out that I.o.d. fuse... Left it out for 15 secnds... Power door locks work again. The old is in the main fuse box,under hood,slot #11.
Old Nov 5, 2012 | 10:36 AM
kenneth 1389's Avatar
kenneth 1389
Originally Posted by deaconite
this is a factory defect for mostly 2005 dodge caravans. dealer must repair this problem for free. there is a TSB regarding this problem.it has something to do with reprogramming the computer. a quick fix is disconnecting for 10 seconds theIOD fusein the fuse box located in the engine compartment. this will temporarily make the locks work for e few days. good luck.
Thanks so much! It worked. Are you sure about it being a free repair at the dealer? My car is a 2005 with 101K miles on it. Kenneth 1389
Old Nov 5, 2012 | 11:24 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
It's not free. The original poster that you quoted was corrected right after he posted that.
Old Dec 30, 2012 | 03:27 AM
freezingmyfanny's Avatar
freezingmyfanny
Default Alternate fix
After dealing with the 05 GC lock problem for 2 years, I decided to try a different approach after the IOD fix began to last only 1 day. The dealer wanted at least $500 to replace the BCM and like most of you $$$ is tight. The software update seemed to be a temporary fix as well so... I got the part and serial # off the BCM ( located behind the fuse box under dash on driver's side). I went to the junk yard and bought a "newer" used one from a scrapped GC with less miles and replaced it myself.( Cost was less than $80.00) Works like a charm. The only problem is that my GC which has 198,000 miles on it now shows 101,000 miles. Six months and so far no problems! Keeping my fingers crossed!
Old Mar 13, 2013 | 09:48 PM
akewldewd's Avatar
akewldewd
It's been approximately 2 years since I encountered the problem with the power locks of my 2005 Grand Caravan. Never brought the van to the dealer for this problem. After unplugging the IOD fuse a couple of times... the problem just disappeared. Oh well!... time is a great healer.
Where is the IOD fuse? What does IOD stand for?
