Have a problem with the right side sliding door, it worked half way in either direction and then would stop...now it does not work at all. I have tried looking for fuses and such but none to be found for this. The left one still works great.
Broken wire in wiring harness for door. Very common. You have to replace the entire harness. Dealer only item. It's called a "cableschlep."
Hi I was reading your answer for the sling door not working I have a 05 Chrysler and my right sliding does not work either, in fact it will no open at all could that be the same problem?
