PCV Valve location
Old Jun 3, 2008 | 05:16 PM
mr_president's Avatar
mr_president
Default PCV Valve location
A friend of mine has a 2006 Caravan, i believe its a 3.3L engine in it, but i am not positive. Anyway just wondering if someone knows the location of the PCV valve. I looked around for it but didn't really see it, not sure if i am just blind or maybe its not as accessible as i thought it would be. Thanks for the help.
- Paul
Old Jun 4, 2008 | 01:20 PM
caravan77's Avatar
caravan77
Default RE: PCV Valve location
Try this . . .
http://www.home-machine-shop.com/Caravan_PCV/
ORIGINAL: mr_president
- Paul
Old Jun 18, 2008 | 04:20 PM
mr_president
thanks for the help, unfortunately i still can't find it, those pics don't match his engine.
Old Jun 18, 2008 | 04:58 PM
TJeepman's Avatar
TJeepman
Look directly behind where it says 3.3 L V6 on the engine. There is a black rubber hose (about 5/8" in diameter) coming up from the valve cover there. It comes up, turns to your left,comes forward and thenconnects to the intake manifold. The PCV valve is located at the valve cover end of the hose.
Old Jun 18, 2008 | 09:55 PM
mr_president
Iam so used to having it visible without taking anything apart. So its under the valve cover then....thanks a bunch
Old Jun 18, 2008 | 10:08 PM
dlstarry's Avatar
dlstarry
" So its under the valve cover then....thanks a bunch "
No it's not under the vavle cover, it plugs into the top of the valve cover.
You don't need to take the valve cover off.
