Speedometer and tach stopped working on 98 Grand Caravan
Old Jun 13, 2008 | 11:20 AM
wabeck's Avatar
wabeck
Default Speedometer and tach stopped working on 98 Grand Caravan
The speedometer and tachometer on our 98 Grand Caravan suddenly stopped working. All other gauges are OK. Vehicle shifts normally. Could this be a fuse? Speed sensor? Something else? Thanks for any advice.
Old Jun 13, 2008 | 06:56 PM
webbee's Avatar
webbee
Default RE: Speedometer and tach stopped working on 98 Grand Caravan
Try removing the IOD fuse in the front fuse compartment for 15 minutes (you will lose your radio presets). If that doesn't work, try slapping the dash over the gauge. If that works you will have to do the solder fix.
As always, good luck with your project!
