Window regulator install
Old Jul 10, 2008 | 09:38 PM
roswellbootie's Avatar
roswellbootie
Default Window regulator install
I am trying to finish the replacement of the drivers side window regulator on my 02 caravan and am having trouble getting the window "clipped" onto the plastic runners that run on the vertical rails. There is a gold lock ring that slides on onece the head is through the hole on the plastic runner, however I can't seem to get the head through. Is there a trick to this?
Old Jul 11, 2008 | 11:52 AM
TJeepman's Avatar
TJeepman
Default RE: Window regulator install
If the clip is in place, and in the right place, you should be able to push the lug through and it will snap in place. There isn't any trick to this that I can recall from doing a couple of these in 2005 / 2006.
This site might help http://www.autozone.com/shopping/rep...00c1528003c929
If not, do a search here or on the Chryslerminivan Forum site. I can find you more info if you need it.
Old Jul 11, 2008 | 01:34 PM
TJeepman's Avatar
TJeepman
ORIGINAL: TJeepman
Further to what I provided above, is additional information if needed:
http://forum.chryslerminivan.net/sho...ight=regulator
