got gauges?
Old Feb 3, 2005 | 08:27 AM
Jesusluvsu's Avatar
Jesusluvsu
Default got gauges?
Hi,
I purchased a 93 plymonth van (mini) aka caravan. on the dash the check gauges light is on.
None of the gauges work only the idoit lights works. The starter must have gone out because when I turn the key I hear "spinning" sound but the light dont go dim. Does anyone have a clue whats wrong whith this thing.
Mark
Old Feb 4, 2005 | 12:21 AM
Red Ram Hemi 2005's Avatar
Red Ram Hemi 2005
Default RE: got gauges?
If you are mechanically inclined you could take it off and go on over to autozone or pep boys and have it tested. as for the gauges check the fuse?
Old Feb 13, 2005 | 12:17 AM
Jesusluvsu's Avatar
Jesusluvsu
Default RE: got gauges part II
Me again the gauges don't work because something called aprinted circuit needs replaced. anyone have a clue what or where this is? the started was bad replaced : on the road again:]
Old Feb 16, 2005 | 01:32 PM
xmax1's Avatar
xmax1
ORIGINAL: Jesusluvsu
The printed Circuit is the instrument cluster itself and is non-serviceable. Must be replaced.
