No Heat (gradually)
Old Oct 9, 2008 | 01:57 PM
deantwi's Avatar
deantwi
Default No Heat (gradually)
i have a 2003 Grand Sport and when I start it when its cold the temperature gauge comes up fast but I get no heat blowing at all.
When the temp gets to half, then suddenly it will drop down a bit and I get heat. But until it drops down from half, I get only cold air.
I checked the antifreeze and it is right up.
ANy ideas?
Thanks
Old Jan 15, 2009 | 07:02 PM
heyjb's Avatar
heyjb
I am having a similar problem, did you ever figure it out??
Old Jan 16, 2009 | 06:57 AM
BenHertz's Avatar
BenHertz
When was the last time you replaced the thermostat and had a coolant flush?
Old Jan 16, 2009 | 07:37 PM
vabear's Avatar
vabear
Default Slow heat
I have a '96 3.3 liter and it does take some time for the heat to arrive, as to the temp gauge, when the needle goes to 1/2 and then drops, it is the thermostat opening
Old Jan 17, 2009 | 02:13 AM
rabbler's Avatar
rabbler
Sure sounds like an air lock.
Does you van have rear heat too?
