VAN WON'T START PLEASE HELP
Old Feb 10, 2005 | 11:23 PM
wantsumtwo's Avatar
wantsumtwo
Default VAN WON'T START PLEASE HELP
I can't get my van to start not getting any gas or fire can you tell me were the map sensor is on a 97 plymouth voyager 3.0 or give me any pointers on what is wrong
Old Feb 13, 2005 | 09:30 AM
Jesusluvsu's Avatar
Jesusluvsu
Default RE: VAN WON'T START PLEASE HELP
COULD be the fuel filter??
Old Feb 16, 2005 | 01:29 PM
xmax1's Avatar
xmax1
ORIGINAL: wantsumtwo
It's possible that your problem is the ASD (Auto Shut Down ) Relay. Check ALL fuses and relays in the PDC located under the hood.
Old Feb 20, 2005 | 01:13 PM
wantsumtwo's Avatar
wantsumtwo
got all new relays pump still won't come on
Old Feb 20, 2005 | 10:46 PM
xmax1's Avatar
xmax1
Did you check the electrical connector to the fuel pump. I believe ther is a connector under the van on the left side attached to the body. Has 4 wires. Disconnect it and check for power with a test light. Since you van is a 97, it may not have this.
You replaced the fuel pump relay? Did you check for power (both switched and constant). You may also has a blown fusible link.
Is there ANYTHING else that's not working?
Old Feb 21, 2005 | 11:47 AM
nmlhaus's Avatar
nmlhaus
Have you determined that it is a fuel problem or a spark problem. An easy way is to spray a little starting fluid in the airbox while someone cranks the engine. The engine should fire (if only momentarily) if spark is good and problem is no fuel. Otherwise.... troubleshooting goes down a completely different path. Good luck!
Old Feb 22, 2005 | 01:52 AM
wantsumtwo's Avatar
wantsumtwo
i checked the fuel its getting to the fuel rail i know, but after that not sure i sprayed starting fluid in the air box and did start for a second and dies could it be injectors it sat up 3 years someone gave me the van not running
