01 Caravan front wiper issue
Old Dec 29, 2008 | 05:33 PM
blacklake1967's Avatar
blacklake1967
Default 01 Caravan front wiper issue
We had a major thaw the other day, so I lifted my wipers to let the ice and snow drain off the windshield (probably has nothing to do with the issue), but when I put the wipers back down I noticed the passenger one wants to sit ontop of the drivers....with a little nudge it goes passed, but it is really close to the other one....actually touches it.
When I run the wipers, the tip of the pass. one rubs against the middle of the driver one at about the half way point, the wipers still do the job but I would guess after a while is may become a bigger issue.
Anything I can do?...perhaps remove and re-align? (I can try to get pics tomorrow in the light if necessary)
Thanks in advance.
Old Dec 29, 2008 | 10:45 PM
eaglestorm's Avatar
eaglestorm
make sure there in the park pos (off) and in the down pos there are nuts under the caps at the bottom of the arm loosen the nut on the drivers arm and repos the arm higher on the glass and retighten. if the arm wont move on the glass lift up like you did to remove the ice and wiggle the are it should free up then move it and retighten both arms (nuts)
Old Dec 30, 2008 | 12:28 AM
blacklake1967
Cool thanks, ...one quick question, how do those caps come off?
Old Dec 30, 2008 | 09:12 PM
eaglestorm's Avatar
eaglestorm
depends it's ether a round cap you can remove with a small screwdriver or the end covering the nut pivots up to get to the nut.I cant remember what it has I see so many diff cars every day my memory stick just dont hold all the small details any more good luck
Old Jan 3, 2009 | 02:02 AM
blacklake1967
Thanks buddy!
