2003 brake caliper piston boot
Old May 24, 2009 | 08:40 AM
paul3102's Avatar
paul3102
Default 2003 brake caliper piston boot
while changing my front brake pads I found 1 caliper piston boot badly worn and torn. Is the boot DIY replaceable and is it critical? Also, I was missing 1 caliper slide (small clip that sits under brake pad), is that critical?
Old Jun 9, 2009 | 04:41 PM
JoeC1981's Avatar
JoeC1981
The boot will keep dirt and dust from the piston seals. If dirt gets in there then the seal will start to leak brake fluid. I would either rebuild the caliper of get a new one.
