ABS--Dash Light
Old Jun 22, 2009 | 10:35 AM
orgum's Avatar
orgum
Exclamation ABS--Dash Light
New here and have been trying to find the answer to this problem and have gotten all kinds of responses. My apologies if this has been asked before, if so please refer me to the rite spot!
Dodge Grand Caravan, 3.8 2002 with ABS light on all the time. Have had brakes checked and nothing found wrong, brakes work great. Have been told ABS mod. needs to be replaced and/or brake sensors on each wheel need re-placing, or Mod. is located near master cylinder, or $525 to fix-[Mod. is $125 on-line-not sure it has one]? No modular near or around brake cylinder, was told once it was under car on drivers side!
Locals know nothing or are wrong-would like to find out. Disconnecting battery does not help! Any advice taken seriously!
Cheers
Old Jun 22, 2009 | 11:20 AM
pherdog's Avatar
pherdog
Did you have the code read? If so, what was the code? I had a similiar thing with my 2003 Dodge Grand Caravan Sport. It ended up being one of the wheel speed sensors. I changed that out and the light went out, after deleting the code.
Old Jun 22, 2009 | 03:31 PM
kev2's Avatar
kev2
ABS light on
step 1- scan for codes-
be advised you will need a scanner capable of communicating with ABS module, read hi end TOOL $$$$. most professional shops will have this cability,
