Hello.
I'm not so sure iF this part, must be replaced with this http://cpwstore.carpartswholesale.co...versal:0)&sv=0 or just the gums or iF I'm wrong at all . You can see the defective part by the use (being separated - spaced). Do you know the right name of the part? is this expensive? Thank you.!! - -- I think iF the change is made both parts must be changed.
These arms are called "link kits" you replace both sides at the same time and better replace the bushings that hold the bar too if there loose........
Very easy to replace
Bushing and both link kits maybe 60$
Thank you! here in mex a seller told us the price of each link kit is arround 35 USD !! and I will ask iF it's the complete piece or just the bushings -- I will try get more pieces and auto parts with a friend in California1 ! :POriginally Posted by MartymanVR6
These arms are called "link kits" you replace both sides at the same time and better replace the bushings that hold the bar too if there loose........Very easy to replace
thank yous again. !
