2000 Dodge Caravan Engine Cuts Out!!!
Old Aug 30, 2009 | 04:01 PM
dragon47's Avatar
dragon47
Unhappy 2000 Dodge Caravan Engine Cuts Out!!!
Desperately seeking advice on how to fix the cause of our 2000 Dodge Caravan's engine cutting out when coming to a stop light/sign, making a turn through an intersection and intermittently on the freeway with no warning. Problem just started this summer. This issue poses a danger and am afraid of being t-boned or rear-ended. There are no dashboard indicator lights lit, just RPM goes to zero. Have replaced the fuel filter...no improvement. Have taken it to AutoZone for a read and there was nothing on it. We've read on other blogs where folks have taken their Caravans to dealers and the dealer's just scratch their heads. No indicator lights, problem doesn't register on their diagnostic tools. We've also read where it could be the EGR, but have also read it's not the EGR. Other blogs have indicated it could be a problem with the Throttlebody. We can't afford to put it out of its misery and replace it with a newer vehicle so we need to fix the problem soon before we cause an accident.
Old Aug 30, 2009 | 04:10 PM
stevesc's Avatar
stevesc
Default Does all the power go out?
If so, it is probably the ignition switch, where the key goes. That is my only guess at this point, I had a similar problem with a Honda years ago.
