96 Caravan headlight adjuster
Old Sep 9, 2009 | 07:25 AM
stix309's Avatar
stix309
Default 96 Caravan headlight adjuster
1996 Caravan headlight adjuster has come loose. Is there anyway to get the ball back into the socket of the verticle adjustment on the headlight assembly. Last night I noticed that the drivers side headlight was aimed almost straight down. I pulled into the garage and removed the headlight assembly. I found the ball and socket of the adjuster had come apart (meaning the ball that moves in and out when you turn the height adjustment screw was no longer snapped into the round socket attatched to the headlight). I cannot seem to apply enough pressure to snap them back together because the assembly moves away from the ball when you apply pressure. Is there away to hold the floating assembly while pushing the ball and socket back together so i have adjustment on my headlight again.
