2001 ignition, heat, compass problem
Old Oct 4, 2009 | 04:08 PM
cooper S's Avatar
cooper S
Default 2001 ignition, heat, compass problem
My 2001 grand caravan ignition will not catch every time I try to turn on the moter, sometimes it takes 10 to 20 trys!!! Then the power to the heater control unit and the compass display failed and I have no control of the air (ie: defrost,floor etc.) and there is no power to the rear window defroster,A/C or intake air(recirc). Then I noticed that the hand brake/emergency brake light was on as well as the ABS light. Also the traction control is noted as off.
Are all these things related to one module or more??
Old Oct 4, 2009 | 10:07 PM
shelbydaytona's Avatar
shelbydaytona
sounds like a bad ground wire at the neg post the small wire to the terminal
Old Oct 6, 2009 | 12:57 AM
KBCobra's Avatar
KBCobra
Does it not turn over at all? Or does it crank but doesn't start?
