2001-2007 fender removal/adjustment
Old Nov 28, 2009 | 10:45 AM
tscaravan's Avatar
tscaravan
Default 2001-2007 fender removal/adjustment
Does the hood & cowl have to come out in order to loosen/remove the fender? Are the hood hinge bolts screwed to the fender? Are there bolts under the cowl that require cowl removal to get to? Thanks.
Old Nov 28, 2009 | 10:56 AM
92dak5.24x4's Avatar
92dak5.24x4
You can't adjust these fenders, none of the bolt holes are slotted. Yes the hood hinge bolts to the fender, no there are no bolts under the cowl, therefore cowl removal is unnecessary. This is a very easy job, you'll need to remove or unbolt other components to access some of the fender bolts
