O2 sensor replacement
Hi all, thank you for letting me join your forum.
I have a 1997 caravan 3.0 litre and i need to replace the downstream (post catalytic converter) oxygen sensor. Can someone tell me how i can do this. i see that the wire from the sensor goes through a grommet into the body. Does this sensor disconnect from a clip like the upstream one or do i have to cut wires and solder them together?
