2009 Caravan Radio Installation
Old Dec 26, 2009 | 05:50 PM
sstafford's Avatar
sstafford
Default 2009 Caravan Radio Installation
I have a Caravan SE I am trying to install an aftermaket radio in. All the car audio sites say I need a C2R-CHY4 adapter. Since this vehicle has a basic radio (RES) and does not appear to have a CANBus interface I can't see the reason for having the adapter. I examined the factory radio connections and they look straight forward. I have not had any luck in finding just a standard wiring harness.
Has anyone had any experience installing an aftermarket radio without using the C2R-CHY4 adapter?
Old Jul 16, 2010 | 01:30 PM
mdunlop's Avatar
mdunlop
The RES radio is on the interior Can bus, check the pin outs on the radio connector, 2 are for Can bus. Without the adapter, look forward to trouble codes because you've eliminated a node. Also, there is no switched 12V supply on the stock radio connector because Can bus enables the stock radio. The adapters can be had for about $75 if you search.
Old Jul 16, 2010 | 04:13 PM
sapporo's Avatar
sapporo
crutchfield (sp?) is a great source for stereo installation kits.
