Help!!! Jounce bumper removal
I am at my witts end!!! Does any one have any idea how to remove the jounce bumper over the rear axel on a 1996 Dodge Caravan LE? I have tried every thing and cant ge the thing off.
Thanks to evry one in advance for your help.
this is the procedure from the factory service manual-
JOUNCE BUMPER
There are two types of jounce bumpers available depending on which suspension option the vehicle is equipped with.
REMOVAL-STANDARD
The jounce bumper is serviced as an assembly. The jounce bumper mounts to the frame rail at a weld nut located on the frame rail.
The jounce bumpers are serviced as an assembly. The jounce bumpers screw into a weld nut located on the frame rail.
JOUNCE BUMPER
REMOVAL-STANDARD
- Using the proper tool, remove bolt attaching jounce bumper to frame rail.
- Remove jounce bumper from frame rail.
- For installation, reverse removal procedure. Tighten jounce bumper to 33 N·m (290 in. lbs.).
- Using slip-joint pliers grasp the base of the jounce bumper. Turn the base counterclockwise.
- Remove jounce bumper assembly.
