Electrical Failure Help PLEASE
Old Jan 23, 2010 | 12:24 AM
brandonl2000's Avatar
brandonl2000
Originally Posted by 92dak5.24x4
what's the BFD, just put it back so it doesn't looked f-d with and take it in for a FREE repair so everthing works as it should. man you sure want to argue about doing it right!!! So what if it's Dodge's fault for it failing... thats why they had a recall because it was failing. It's your dads fault for not doing some minimal research into the problem
damn. someone ate all your cheerios today.
im a perfectionist. what can i say.
but thanks anyway..
Old Jan 23, 2010 | 11:05 AM
92dak5.24x4's Avatar
92dak5.24x4
if you really were a 'perfectionist, you wouldn't be driving a cobbled vehicle and you would have fixed the screwed up horn situation way before all the other stuff failed. Which inturn, you'd never would have posted this to begin with.
Old Jan 23, 2010 | 11:07 AM
92dak5.24x4
if you really were a 'perfectionist, you wouldn't be driving a cobbled vehicle and you would have fixed the screwed up horn situation way before all the other stuff failed???. Which inturn, you'd never would have posted this to begin with....lol
Old Jan 23, 2010 | 11:15 AM
brandonl2000
i jus started driving it recently sooo.. yea.
Old Jan 23, 2010 | 11:31 AM
92dak5.24x4
you sure are contradicting yourself. you have a cobbled together horn, you are trying to get around fixing the thing thru a FREE repair because of this issue... a 'perfectionist' would uncobble it and get the free repair. to go back to your question about fixing it yourself. go right ahead, buy the clockspring $100+, buy a steeringwheel puller, and any other tools you don't have. then after you fix the problem yourself, a true 'perfectionist' would also fix the butchered horn issue... so why not fix the butchering first then get it fixed for free. I suppose he drilled a hole to mount the bypass switch? then you'd need to replace these comprimised parts as well
Old Jan 23, 2010 | 12:10 PM
brandonl2000
i plan to "uncobble" it and get it fixed for free. thanks for your help.
Old Jan 23, 2010 | 04:25 PM
92dak5.24x4
Finally!
