2008 Caravan blower resistor location
LHD model shown. RHD model similar.
1. Disconnect and isolate the negative battery cable.
2. If equipped, remove the silencer from below the passenger side of the instrument panel.
3. Disconnect the wire harness connector (2) from the blower motor resistor (3).
4. Remove the two screws (4) that secure the blower motor resistor to the front HVAC housing (1).
5. Disengage the retaining tabs (5) that secure the blower motor resistor to the HVAC housing and remove the resistor.
I am assuming there were pictures that use to go with this if so could you repost or add a link so i can see where this little sucker is? Thanks
thanks! once i pulled the resistor/fuse out i saw that the soldered fuse was open. by holding the fuse back in place i was able to use a cheap solder iron to reconnect it in just a couple of minutes. the cheapest i found the replacement part was over $80 and didnt even ask how much the dealership would charge! AGAIN THANKS TO ALL!
