How can I remove the Key Clyinder Lock?
Old Feb 18, 2010 | 09:19 PM
ez1913's Avatar
ez1913
Notice the silver tab on the bottom, that's the tab that will release the cylinder, if you can get it to run position.
EZ1
Old Feb 18, 2010 | 11:38 PM
ripvnw's Avatar
ripvnw
Thanks again EZ, I'll be back at it again tomorrow afternoon and let you know.
Old Feb 19, 2010 | 09:14 AM
Tizzy1's Avatar
Tizzy1
When your key won't turn, insert the key into the cylinder and smack the end of the key toward the cylinder 3 or 4 times, keep doing this until the key turns. It doesn't usually take that long to get it to go. When in the run position, depress the underneith tab and remove the cylinder from the column. Then it is up to you weather you replace it or try to clean it.
Old Feb 20, 2010 | 03:49 PM
ripvnw's Avatar
ripvnw
I actually tried again tapping a little harder with the hammer and did get it to turn. BUUT, even in the "RUN" position, with the pin/tab pushed in, the cylinder will not slide out. Any other suggestions?
Old Feb 21, 2010 | 04:58 PM
Hymyldsl's Avatar
Hymyldsl
To all, this happened to us with our 2000 Caravan about a month ago, after about a half hour it worked. I was just called by my wife about2 hours ago saying it happened again. Only she is almost 2 hours away. I imagine that I will have to replace the lock cylinder but I told her to try the WD40 trick to get it home. One interesting note is that the steering wheel is not locked. Thanks for this good info to get me "started" on fixing it.
Old Jun 23, 2014 | 10:43 PM
Chinthe's Avatar
Chinthe
Default ignition cylinder
I'm having the same problem with my 2002 caravan.
I have the ignition cylinder out, but can't take it apart.
Old Jun 24, 2014 | 11:02 AM
Tizzy1's Avatar
Tizzy1
have to turn it backwards like going to accessory and hold the brass pins on the end by the key down.
