Electric fan controller
Old Mar 4, 2010 | 10:39 PM
dakota_raven's Avatar
dakota_raven
Default Electric fan controller
My wife has a 2000 Dodge Grand Caravan V6 3.3L and i need to replace the Electric Fan Controller. Anyone knows where is located ?? Thanks for the help!!!
Old Mar 21, 2010 | 01:52 PM
Leif186's Avatar
Leif186
Are you talking about the fan attached to the radiator or the heater fan?
If it is the heater fan/blower, it is behind the glove compartment. Empty the compartment and pull in the sides so it drops down. The "resistor" is inserted into the plastic tubing where the air flows. It should only cost about $15.00 and 5 minutes to replace (well then that depends on the neatness of the present contents of the compartment...WIFEY!) As you can see, I have replaced it before. It goes bad every few years and also controls the rear system blower in my van.
If you are talking about the radiator fan, sorry, but I have no experience with that one.
Good luck.
2001 DODGE GRAND CARAVAN SPORT
3.3L FLEX, 194K+ MILES
Old Mar 22, 2010 | 12:09 PM
dakota_raven
I changed everything! All went ok, and the electric fan controller is under the left headlight, that was a pain in the butt to take out but everything worked out ok!!
Thanks for the info to all
Good luck.
